Removing 3rd row flooring, what to fill recesses with?
mikez71
mikez71
Vinyl flooring is unforgiving! Carpet makes up for a multitude of sins..
I couldn't take it anymore. Got some 3/8" thick rubber interlocking floor tiles from home depot. Would have preferred solid rubber, which is easier to cut and not crumbly, but the tiles were cheaper. Should have bought 3/8" to begin with.
used 3 out of 4 tiles, but still using my old rubber pieces in the seat latch holes. The diamond tread rubber pieces were cut to put over the lower raised ridges. about 1/8" to 3/16" thick. I was hoping they wouldn't be needed, but even those shallow little 1-2" squares (tip of scissor) are VERY noticeable through the jute and 2 layers of vinyl!
Not done in the photo, but u get the idea.
UPDATE: Worth it! Knees feel good! No more wobbling/pain over the ridges. Probably faster and easier to pour some polyurethane, as was recommended, but if you want to play with scissors all day long..
ccole
Great idea on the tile. I filled the concave spots with sound deadening material and closed cell foam. As mentioned previously the carpet I used is more forgiving than vinyl. I used the highest quality automotive carpet from an upholstery shop and it turned out better than expected.
The wife and I have relaxed back there watching the sunset. Rather comfy especially since I used 100% coverage with jute after the sound treatment materials.
Hardcore acoustic treatment of my truck has been one of my favorite upgrades.
Scrappycrow
Alpharetta, Georgia
I'm late to the party, but a suggestion for anyone doing a future endeavor like this is to use "casting compound." It's not inexpensive, but will flow and form a level rubber surface, and you can get it in different stiffnesses. If you use a release agent beforehand, it'd be easily removable.
EddieC
That's interesting. Wonder if it would do a large area and still be removable.
I miss the old days when the vehicles had a one piece insulated flexible vinyl like floor covering.
sbt2003
