persistent
- Joined
- Nov 10, 2023
- Posts
- 83
- Reaction score
- 72
i'm almost ready to test my dod delete work, and i need to refill my transmission fluid. i have 12 qts of dexron ulv on hand and another 5 qts ordered.
i had the radiator/cooler disconnected and drained the transmission fluid from the pan and replaced the filter. i had to undo the 8 mm hex fitting on the left side of the transmission pan to drain it.
i see comments that suggest there should be a fill/vent plug on the right side of the transmission pan, but i couldn't find it on the 10 speed transmission. additionally, i don't see a transmission dip stick in the engine compartment. i only have the service manual for the 6 speed transmission, so i can't find good manual info for the 10 speed.
can someone give me input on the fill process for this transmission? i would like to do a flush while i'm at it, but that seems pretty challenging to do without a dipstick tube for the filling.
