10L80 - filled transmission at wrong temp???
BlaineBug
Clown World
Thanks guys. I've scheduled an appointment with my dealer for Monday of next week. Thankfully, they're not THAT bad, and have taken care of me on a few occasions, so I trust them.
I visit dealers regularly for warranty claims. Dealer doesn't necessarily mean competent and honest, although their work bays are always clean and have plenty of room, unlike the shade tree shops of the ghetto.
J
jyi786
...and as expected, the stupid dealership said they could not replicate it, so they assigned it to the "shop foreman", who said he couldn't replicate it, and reached out to GM TAC for support.
I asked if they even listened to anything I said, because if you simply connected a bi-directional scanner to it and watched the graphs as you drove, you would SEE it.
I told them that you can 1000000000% replicate it, especially when the powertrain is cold. I offered to show up and take them on a test drive, which they accepted. I showed up, took the shop foreman on a test drive, and was able to replicate the issue in under 30 seconds. Additionally, I replicated it a whole bunch of times, so there was no question. So only THEN did the shop foreman say he would connect the scanner to it, drive it, gather the info, and then forward on to GM TAC.
So I'm obviously still playing the waiting game. :rolleyes:
J
jyi786
Finally an update.
The dealership had my truck since Monday morning. On Tuesday evening, I called them asking for a status update. They said they'd have an update for me later that evening. I never got that update. So I waited until Thursday morning, and called. What do you expect: I got the same old line. They assigned it to a tech, who "could not replicate the issue". So they assigned it to the shop foreman, who also "could not replicate the issue".
Incredulously, I said to them that it is 10000000% easily replicated, each and every time, and offered to come to the dealership again to show them. They agreed, and the shop foreman came along for the ride. Within 30 seconds of me getting into the driver's seat, I reliably replicated the issue, and made sure the tech actually felt the shudder at least 3 times. I asked him if he wanted to bring the scanner so that we can do it again, and he said no need, he had all that he needed to proceed.
Fast forward to this evening, I called them for a status update, and the service advisor reported to me that the shop foreman tech finally indeed did find "codes on the TCM" and on the output graphs which indicate clear TCC slippage. The reasoning they gave for "not believing" what I was telling them is that they have never seen a 10 speed transmission fail, and so were completely caught by surprise that it was indeed the case.
They said based on the diagnosis that it was one of three things:
1. Solenoid/s
2. Valve body
3. Torque converter
They said since it was narrowed down to those 3, they would start doing a more in-depth diagnosis in that order (which is also in order of ascending cost) to determine which of the 3 are the problem, and then provide me with an estimate on repairs early next week.
In hindsight, if they would have just done what I asked them to do, they could have saved me a wasted week, because I literally told them what to do, and expected that it was TCC shudder. Whatever. That is behind me now, and I need to focus on getting this fixed.
@NickTransmissions, what are your thoughts on which of the three it might be? I'm really hoping it's either the solenoid or the valve body, because I know from experience that these two are much less expensive than the actual torque converter.
Seamus
Palm Beach
I was just at the dealer regarding a coolant leak. I happened to speak with the tech who did my friends 2020 10 speed. His is a 3.0 Duramax. His exact words: There are two gears in front of the pump that go bad, subsequently takes out the TC and contaminates the valve body. Said it sounds like marbles when this happens. Said if caught early, replace gears, replace TC, replace valve body, filter, and flush when taken apart. Said if there is any crap in there the TC must be replaced as it cannot be flushed out. ---I asked about my 2018 Escalade and should i be concerned? His response: Never had a bad one here only the 10 speed behind the 3.0 Duramax has issues. They have been a great trans he said. FYI
Side note: They had about 7 2021+ yukons and silverados in there for cams, lifters and bottom ends. Said anything past 2020 is a nightmare motor don't ever consider it. Said thats all they do, its worse than the internet ! LOL When do you ever hear a tech say that??
He owns a 2018 and said delete it and call it a day
BlaineBug
Clown World
Isn't this the same 10-speed made in partnership with Ford where one of the drums is able to slide back and forth a bit causing a shudder OR a very harsh and firm shift?
NickTransmissions
Sin City
The transmission bench
Finally an update.
1. Solenoid/s
2. Valve body
3. Torque converter
It's hard to say what the root cause is/was but generally speaking, any shuddering is the converter clutch, regardless and once that starts, it is generally not advisable to keep the converter installed...So the only real question is whether the failure started in the converter or was caused by wear in the valve body (TCC priority and/or regulator valve circuits) or TCC solenoid.
Basically what I'm saying is you could be looking at replacing the TC and valve body/TCC solenoid not just one or the other...Shop will pull the valve body down, throw it on the Sonnax vacuum test machine and determine if there's sealing integrity issues with those two valves which are responsible for torque converter clutch function...If weakness is observed, they will want to replace either just the TCC priority valve w/a Sonnax valve or perhaps the entire assembly which will come with a new TCC solenoid. I would be surprised if they only recommend solenoid replacement but what they may do is offer to try that first as it would be the least expensive solution, do a test drive and assess from there whether anything more is necessary.
J
jyi786
Ok thank you.
So what do you recommend I do? Sounds like I have 3 options:
1. Let them continue to diagnose and go in order of repair for those 3 components.
2. Ask them to replace the TC/valve body.
3. Ask them to install a completely brand new (or remanufactured) transmission.
I also reached out to another transmission building company and am asking for their quotes on those 3 components.
NickTransmissions
Sin City
Ok thank you.
They still have the vehicle, right? If so, let them diagnose it, tell you what's wrong and what must be done to fix/cost of repairs. Then make a decision based on what they say...If the price is too high or you dont agree with their conclusions, obtain a second opinion from another shop. Do not just ask them to start replacing parts without a diagnosis.
Rink
