Security light won't turn off!!
Rockman101
2012 security light won't go out, tried the leave the key on for 10 minutes, but light never turns off no matter how long key is. At first security comes on than will turn off for a split second than Back on and stays solid . Won't crank either. Battery and cables are new. Can't seem to find a picture diagram of all the ground locations. Any suggestions will be appreciated.
donjetman
read owners manual about theft deterent systems
2012 requires 30 minute relearn so 10 minutes X 3 , let it sit 10 min, turn key off momentarily, turn back on for another 10 min, repeat 3x
Light never goes off. Like all the videos I've watched.
then you might have something else going on
like bad key chip
bad security ring/module
something in the ignition not reading correctly
or who knows, you might try seeing if a locksmith can do it with there tool
BKraft
