I got me a Tahoe!
j91z28d1
I've already hit my first head scratcher. How am I missing the fuel pump relay but the vehicle fires up fine?
it's a common head scratcher. the newer ones have a fuel pump module under the truck that runs the pump. the older ones had a relay.
pull the fuse.
N
Nutro
Ok so there is no fuse there haha. What the heck
j91z28d1
my software shows fuse 56 ecm-ign fuse sends power to the ecm and the fuel pump module.
you can also unplug the injectors if it's easier.
N
Nutro
So I check compression on number two as well and it was right at about 168 also. I pulled the valve cover and had my dad spin it over and all of the rocker arms are moving like they should. Even number four that has a cylinder misfire the intake and exhaust Rockers are both moving up and down as it Cycles through the start. I don't see any evidence of a broken valve spring or at least I don't see any cracks
GMT800 SUV/Trucks
Military
I never asked. Can you see/feel a misfire at idle? Can you feel a misfire when driving? What exactly was the code or is the code? P0304?
Stevemo70
