Fixed:Everyone’s fav topic: 6l80 issues
Starkworks
2020 Chevy Suburban w/ 110,000 miles
Before tear down issues: progressive slipping/flares from drive. Noticed predominantly after driving for a period of time and warmed up. Able to engage and drive after a period of cool down. A code finally popped up with a p2723. Lost all gears, including reverse. I had to have the truck towed home.
During tear down:
- metallic dust in the pan. Assuming torque converter failure, I proceeded with a complete tear down.
- Pulled apart the valve body. No check balls in appeared to be shrunken or stuck. The valves appeared to be free moving and no excessive wear on any of them.
- TEHCM: all TFP switches were intact.
- Disassembled Stator Pump: slight scarring on the pump body side and pump cover surface.
- 1-2-3-4/3-5-R housing, friction and steels looked good. Pistons good. Bearing no abnormal wear. O rings intact. No apparent cracks in weld.
- 4-5-6 housing, friction and steels were burned up. Piston looked intact. No cracks in housing though.
- center support and components looked good.
- 1-2-3-4 clutch hub looked good
- 2-6/3-5-R clutch hub looked good
- Rear carrier was intact and all gears were freely spinning.
- output carrier was fine.
Assembly:
- valve body: cleaned and installed transgo kit with new check balls. Vacuum checked all valves.
- TEHCM: cleaned and changed orange pressure switch covers and seals. All continuity testing was good.
- Stator pump: buffed out the slight scarring. Installed transgo valve kit. New seals. Reused other components. Installed new gasket.
- kept all bearings throughout as they didn’t have any scarring and thrust bearings moved easily. Nothing appeared out of place.
- replaced all frictions and reused metals in all but the 4-5-6. Replaced 4-5-6 metals and frictions.
- 4-5-6: new pistons, frictions and steels. New Teflon. Pressure checked on stator.
- 1-2-3-4/3-5-R: new frictions and pistons. New O rings. I did not specifically test for leaks as I heard that the welds are improved in the newer 6L80s. But, I did place on stator and test. No leaks that I could tell. Stator kept pressure as well.
- 2-6: new frictions
- low and reverse: new frictions
- center support: pressure test was good
- lubed everything up
After assembly:
- refilled with dexron VI
- started the truck up and have reverse. Drive works, but doesn’t shift. Flares at about 5 mph
- checked manual mode:
- 1st flares around 5
- 2nd feels like it’s binding? When in second truck doesn’t move at all and feels stuck.
- 3-6 flare around 5.
- hooked an autel scanner up and solenoids and switches appear to be working in the mode they are supposed to.
- went ahead and ordered a TEHCM, but will wait to install until I can rule of everything else.
- thermostat bypass
- reman converter
No clue what to try from here. I am an amateur at this but love learning about these transmissions! Watched quite a many hours of @NickTransmissions, which has been a huge help.
NickTransmissions
Sin City
The transmission bench
Good on you for attempting the rebuild, many wont for a variety of reasons. A few questions:
1. Did you perform a fast relearn prior to your test drive?
2. What were your clutch clearances for all clutch packs
3. Did you replace the stator-to-stator support gasket?
3A. If yes to Q3, did you follow the prescribed torquing sequence?
4. Did you machine the pump body/bell housing?
4A. If yes to Q4, what was the rotor/slide to deck clearance?
5. Did you replace all bushings?
6. Did you conduct any vacuum testing on the valve body and pump valve trains?
I'll prob have more questions depending on how you answer these but your responses (hopefully) will give us something to go on...
S
Starkworks
Thanks, @NickTransmissions Answers below
1. Did you perform a fast relearn prior to your test drive? Not exactly sure I did. I see the option in my Autel and select it, but it doesn’t have me go through the process.
2. What were your clutch clearances for all clutch packs. Shame on me, but I didn’t check. Assumed I was using the same thickness as OEM.
3. Did you replace the stator-to-stator support gasket? Yes, replaced that gasket.
3A. If yes to Q3, did you follow the prescribed torquing sequence? Yes, followed the torque sequence.
4. Did you machine the pump body/bell housing? Not technically. I buffed the slight scarring out on both.
5. Did you replace all bushings? No
6. Did you conduct any vacuum testing on the valve body and pump valve trains? Valve body, yes. Pump, no.
NickTransmissions
Sin City
@Starkworks - Conduct a successful fast adapt relearn and take it for another test drive - that by itself may solve all the issues. If you do have to pull it back out and apart, do the following:
1. Replace all the bushings - do not reuse bushings in these transmissions, especially the pump stator and body bushings
2. Vacuum test the pump (not sure why you didn't test the pump with the valve body but you don't want to omit that step - this video will show you specifically how to do it and what your readings should look like)
3. Record and share your clutch clearances, pump rotor/slide-to-deck clearance and end play measurement - this is one of the most critical aspects of any build and one of the most common things I see w/DIY builds is folks not recording clutch clearances and end play measurements
- If your clearances are too tight, you will have partial tie-ups/bind-ups upon shifting - these, like all clutch-to-clutch transmissions, are sensitive to clearances
4. Air check all applied elements to confirm everything is working as it should
5. Take pictures as you go - don't skimp on this step as they may help you after the fact - ask me how I know!
6. If all of the above is done and you still have the same problems, replace the TEHCM - a brand new one from General Motors will run ~$1,050 plus core and programming.
- Sonnax reman TEHCMs are $550-$600 plus core and programming
- Street Smart Transmissions remans are $550-$650 w/programming (you give them your VIN so they program it to your vehicle)
S
Starkworks
Roger that @NickTransmissions
Looks like rookie mistakes all around. Let me see if I can get this Autel to cooperate.
NickTransmissions
Sin City
S
Starkworks
Well, looks like this Autel doesn’t have the relearn on it. I could have sworn this one had it. Returning and getting another.
No worries - we were all rookies at one point and I have made my fair share of them.
Let us know the results of the fast adapt relearn...Also, if you don't already have it, download the ATSG manual from my 6L80 Information Thread, page 1 - first post: https://www.tahoeyukonforum.com/threads/gm-6l80-transmission-information-thread.141927/
senseicraig
