Describe to me how the 2-speed transfer case works... 2011 Tahoe 5.3
hillstrubl
Coming from the jeep and Land Rover worlds, I understand their transfer case offerings well... School me on what's in my 2011 Tahoe (5.3, rear locking diff). Auto obviously engages the front diff but on the transfer case side, is it just an open center diff? Viscous coupling? Clutched center diff? How does it know when/how much power to send to the front?
I get 4Hi, N, 4Lo settings + locked center diff modes. Its the auto setting that I'm asking about.
- follow up question, as I have the rear locking diff, what type is it? limited slip, clutched? geared? Does it actually lock-lock if given the conditions to do so? I've heard chirps when going around turns in slippery conditions in 2wd previously, just wondering what triggers it and if its tied into traction control at all.
wjburken
Eastern Iowa
When are in Auto4WD, your vehicle will engage the front wheels, just as in 4HI, as needed, based on what the wheel speed sensors are reading. If they sense wheel slippage, it will engage the front wheels and then disengage when everything is back to normal. There is no varied splitting of torque.
Super Moderator
Elev 5,280
Should be the NQH TC. Take a look at this post and the embedded thread to see if it's what you're looking for:
I forget which models, a lot of Jeep offerings also use the same Magna Power transfer cases.
hillstrubl
hillstrubl
The internal clutch application in the A4WD position is controlled by the transfer-case shift-control module (TCSCM), which sends a pulse-width-modulated signal in response to input from the wheel-speed sensors. The actuator motor turns a gear-driven actuator shaft, moving a clutch-application cam to engage the clutch and send torque to the front axle. When the front and rear axle speeds match, the actuator motor returns to the 5% duty cycle.
This sentence was what I was looking for, thank you.
I assume these clutches have a service life, any idea what that is? I guess if it's spent most of its life in 2wd (or 4wd high when needed) they should be in good shape though.
j91z28d1
I seem to remember when I first started looking around, most people thought the t case was good for about 125-150k miles if it was always in auto mode.
best to drive around in 2wd on the nice sunny days, and save auto for days you might need some awd help. unless you're one of the guys that gets a new vehicle every 100k or. less.
j91z28d1
I had one 135k on mine when I got it. no clue how it was used but I doubt every hard life being a hybrid. but it could have been in auto a lot. the t case fluid was black and the magnetic drain plug had a scary amount of fluffy on it. I changed the fluid and then again 500 miles later and just hope. but so far it seems to be OK? not that I ever use it besides just testing to see if it still works.
hillstrubl
hillstrubl
Nope, I got this one at 100k, well maintained but had an easy life. Used 4Auto/4Hihh a bunch in the snow this weekend, it definitely grabbed immediately in Auto, I'm pretty sure the clutches are in good shape. I recently changed all the fluids and the tcase fluid looked fine, no metal either.
