2025 new tahoe/suburban feature wishlist
Polo08816
Back in August when I posted that it was up for an instant. When I went back a day or so later to explore it was gone. Might have been a test. I do believe the new configuration is up now? On about sept 3 it was up and I put together a new 2025 suburban when the first orders opened up (my local dealer called me and they had ONE allocation) but went with a used one with 38K miles and 100K mile warranty for HALF the price. I still have two girls in college!
I don't think it's up.
nomech
Senior Member
The auto stop start needs to go or just have a way for it to be set to off until you want it back on. However, I’m not sure why anyone would want this feature.
JayceeP
Why does everyone dislike it so much?
Protect1989
Because when I pull up to a stop sign and no ones there but the engine immediately shuts off and then kicks back on again, it’s annoying.
It’s even worse if there is another vehicle.
I agree that there should be the ability to turn it off permanently. If you like it, keep it on. At the end of the day it’s your own vehicle, you should be able to remove it
JayceeP
GM doesn’t seem to like “permanent”. It’s the same hassle with the damn fog lights. First car I’ve owned in 15 years that this has been an issue and it drives me absolutely nuts that I need to manually turn on my fog lights every freaking night!
KMeloney
You guys do know that you can install a harness (or a module) that defeats this permanently, right?
nomech
Senior Member
Yes, I've seen that posted in another thread. We are saying that it should be a setting in the vehicle that you can disable. You shouldn't have to add a wire harness to disable auto start.
zephyr
