2007 Yukon Denali Intermittent Crank No Start
rdezs
are we confusing cam with crank sensor? he replaced cam sensor but these will run without a cam sensor. they won't run without a crank sensor?
I'm a bit lost lol
Aftermarket camshaft position sensors are notorious for a crank no start symptom, with no codes thrown. The last time I run into that was with a Wells brand. Tech 2 said it was getting the signal.... Swapped it out for an oem ACDelco, and it fired right up. Personally, I would look no further until I replaced the camshaft position sensor with an oem unit followed by a CASE relearn.
donjetman
no need for CASE relearn after a CAM position sensor change. I changed mine last summer.
rdezs
It will run forever without doing the relearn.... But it just won't be as efficient as it's capable of without it
rdezs
The mpg is probably a pretty good indicator that it's right on.
I was thinking it's a lot like when I was working on my first small block Chevy, setting the point gap and the dwell. It would fire up and run okay. Put a dwell meter on it, and realize I only got it close.... Was off maybe 10° on the dwell. Just like setting the distributor to get the engine to fire up. Always follow up with a timing light to get it perfect. There's nothing better than absolutely knowing it's on the money. (Sort of like checking the push rod length)
But yeah, if fuel mileage is staying the same, that's probably the best measurement overall :)
rdezs
The important ground is where your negative battery cable goes down to just above the oil pan on the driver side. Don't just clean and reattach.... Check the resistance of the negative cable to make sure it's serviceable. Then the ground strap from the back of the engine up to the firewall. Depending on the year, you'll probably find another ring connector where the battery cable attaches to the block. Normally that is routed to near the front of the frame rail on the driver's side. Don't forget to also check the resistance of the positive battery cable.
M
Maxpower_454
Thank you! I'll work on all of this
M
Maxpower_454
Ok so I cleaned the front pass ground and tested the negative cable. All good.
It just died again on me last night. The problem appears to be more frequent now. It'll start idling lower and lower struggling to stay running at stops. Then the next tine I stop, it dies and won't start. Could it be throttle body and/or MAF sensor?
JayySalas
