Looking to buy a work truck. Need expert assistance.
Bigburb3500
I managed to cut a deal. On it for 2700 truck is sweet. High milage, but it is really good serviced.
What do you think?
Total fan of it! I bought my 01 with 280k on it and it didn’t have even 1/10th of the records you have and I beat on it for a year and 15k miles before it had issues. This is a nice… NICE truck with the 8.1 and 4.10. You got yourself a killer deal because of you drive it for a year or two and clean it up a bit it will be worth $2800. Great buy and you will love it.
M
makintoshnex
Here we go picked it up yesterday. I need to figure out how to eliminate opening noise on back doors. Rear driver side wi doesn't go down. When button is pressed it makes some noise for a sec and then nothing. Window is not moving. Pump is making a bit of noise. I will fix it when it will be warmer. I want to change shocks for more comfortable ride (what shocks would you recommend?). Later on after threads will go down I will swap out wheels. I think 20 or 22 , but for now can't find anything that will fit.
Bigburb3500
I have the Rancho 9000 adjustable and I like them. Not expensive either. Highly recommend and can be bought on RockAuto.
Don’t do 20s. Will sacrifice ride comfort. Stick with 18s.
The window is likely the regulator. I think those are known to go out. I think there are several threads talking about it.
M
makintoshnex
Thanks for informing. By the way I will need to swap out towing mirrors. They are automatic, but only with adjustment. I want to make them fold automatically. Do you happen to know how to do it? I saw some on Amazon for $100 with automatic folding, but how to make it work with my Yukon XL, I have no idea.
Bigburb3500
Ooo… adding folding… not 100% sure for your gen but I think it can be added with the correct mirror switch. I did not have power fold on my Sub like yours but I’m sure someone here will be able to help more!
M
makintoshnex
Got and abs light. But it glows steadily not flashing. I hooked up a scant tool. Appears to be front wheel speed sensor. I ordered it from Rockauto already. Should be by the end of the week. Also I would need an oil change. Sometimes light is on sometimes it is not. I think I will do both of them at mechanic shop. It's not a complicated job. I will have to use to this truck. It's huge, but still not as huge as my Sprinter. I will add top view rear camera and parking sensors to it. And also will remove rear bumper. I will install Street Pan roll. And modify the towing hitch. Those few inches play a lot in NYC.
M
makintoshnex
Have someone tried These wheel adapters. I can't find budget wheels for 8x165.1 maybe I could get lucky with 8x180. Looks like my truck has factory 2 inch lift. So I should be good with 20 inch rims. I'm not planning to install huge 33" or 35" just a bit more stylish rims. Tell me what you think
KodiMoe
