Does anything go in the blank spot?
nomech
Senior Member
This is the inside of a 2025 tahoe HC with deluxe option, is this spot blank (upper right) on every tahoe? I don't recall seeing a picture that had 100% fill, something is always missing. Some it is air ride up/down, others don't have the trailer brakes (not only HC, but all the trims I've looked at) but I'm not sure if anything should be in this spot (upper right).
Does anyone know? (image should be below in case it fails to load)
Hobert
Downers Grove, IL
That is in a 2025 HC? I'm looking at one, right now, with HUD and it does not have those controls you show. Your picture doesn't seem to have the same backing/trim/etc as the pic I posted.
My bad, that was a 2023
Stevemo70
