2001 Chevrolet Tahoe Won't Start
Carseller235
We bought this SUV and it was running at the time of purchase and afterwards too but now it isn’t. It won’t start. Also it hasn’t passed smog. Wondering if we should try to get it fixed or sell it.
Scottydoggs
NJ
a engine needs 3 things to run, air, spark and fuel.
so make sure the air filters not clogged up, check for spark, you can pull one wire off the coil and prop it next to the coil hole where the wire was, when cranked a spark will jump to the wire, and then on the fuel rail driver side under the engine cover is a shrader valve, like a air valve on a wheel, turn key to run, then push the pin in, watch your eyes cause it should blow gas out around 2 ft high. if it dribbles out the fuel pump is likely dead, or if your year has a filter located pretty much under the drivers seat in the frame rail is clogged up solid.
lastly the cats can clog up and then the engine cant exhale. remember Beverly hills cop movie, bananas in the tail pipe? same deal.
justirv
Forgot pic so here it is.
You'll want to follow @Scottydoggs advice and get things running first. Regarding smog, you didn't say what state you're in, and whether you attempted to smog before the "not running" situation popped up. A momentary loss of power to the ECU can reset all of your emissions readiness monitors.
C
Carseller235
In California. Attempted to smog before not running. Doesn't pass smog as no GM catalyic converter label and no cold air intake label.
C
Carseller235
I know very little about cars. Should I just take the tahoe to an auto electrician to get it fixed? You all are saying fix it before selling it. I am not sure if it's even fixable.
rockola1971
Indiana (formerly IL)
Does nothing when trying to start it.
So you mean engine wont crank over? Because thats very different from engine wont start which usually means engine cranks over but will not run...>Depending on who you are talking to which is why I asked.
So you have a starting circuit problem and NOT an ignition circuit problem.
Can you hear starter solenoid click at the solenoid? Is battery charged up? Are battery cable connections loose or corroded?
Tjf2222
