Knee deep in first transmission rebuild, opinions welcomed.
osirus5164
So, I'm putting everything back together and the sub assemblies are pretty close. I was curious what everyone's opinion was on case savers vs anti clunk spring. Yes no meh?
Second, is load release springs. They're on the table but I would need to order new springs. Crusted in clutch material.
Another curiosity, front pump. So I see that the 073 casting is the same through years aside from the o ring vs wedge seal. My dude has damage to the pump body side but the stator inside is pretty decent. There's lots of options available for the body but they are all boring style. Does that machining for the o ring make it unusable in wedge seal application? I am going to be calling a guy who was recommended as far as surfacing my old one but I'm still curious just in case. Is there anything that I would have to take into consideration with the loss of material or is it negeglable and rebuild as normal? Thanks guys!
Just for kicks, I'll tag @NickTransmissions . Maybe you'll see this while you're having a cup of coffee in the morning and I'll be privileged with some of that valuable insight that I've used in this project thus far.
NickTransmissions
Sin City
The transmission bench
Pump body casting ".....073" never changed from 1996-2013 outside of the o-ring vs wedge seal, starting in 2004 (wedge seal) - don't mix/match wedge seal cases and o-ring pumps.
Those doing the machine/resurfacing work will know what to do. Have the pre-existing pump resurfaced/re-cut or purchase an equivalent already machined to new condition and check clearances before you assemble it.
Use the anti-clunk spring unless you're racing.
mountie
Nick... For a year, I was honored to work for the famed, Art Carr " Performance Transmissions ", in Huntington Beach, Ca.
I R&R'd trannys & installed coolers. I knew nothing about transmissions, but being around his artists, was quite an experience.
He built me a transmission & converter for my '88 GMC truck ( could handle 650 HP / 700R4 ) .. Since, my transmission failed 6 times before I met him..... He is famous for his STOUT, 2004R builds.
osirus5164
osirus5164
@NickTransmissions , thanks! I am also leaning towards not reinstalling the load release springs. It's a stock 08 Tahoe (nicknamed lovingly, the MaHoe) that has yet to see any towing and Mrs lead foot may jockey for position on the freeway but that's about it. Flip side, better safe than sorry?
Another hing thing I was curious about is the 3-4 pressure plate. The old one is pretty smoked and when I hold a straight edge to it in the light it seems a little off. It's got legs on it, most options I see online are flat
For reference I'm comparing part numbers:
74141ae
74141b
Was this a change that was made at some point or are these two completely different fellas?
osirus5164
osirus5164
Also, I built the stack last night just to see and I had .110 clearance. Gonna go back and see if I goofed somewhere.
Edit: stack is alto power pack. Asked for some .106 steels but parts guy sent .076 steels. Should still be mix and matchable?
NickTransmissions
Sin City
Another thing thing I was curious about is the 3-4 pressure plate. The old one is pretty smoked and when I hold a straight edge to it in the light it seems a little off. It's got legs on it, most options I see online are flat
74141ae
74141b
Not sure as I never use part numbers; I simply buy the pressure and backing plate set from my hard part supplier for either the 4L60E or 4L65E, depending on what clutch set I'm using...You can buy the 4L65E clutch pressure and backing plate set plus 7 high energy 3-4 friction plate and 6 lindered (heat coated) flat steel plates. If you run your clearance down to below .045, reuse the load release springs but if not, you can leave them out.
osirus5164
osirus5164
Do the plates always have little legs on them?
NickTransmissions
Sin City
4L60E pressure/apply plates always have support legs to mesh w/those on the 3-5-R apply rings. The 700R4s used a sheet metal style apply plate support with the legs and a non-legged version of the apply plate. There were numerous different thicknesses of 700R4 apply plates, any of which can be used in a 4L60E as long as you also install the sheet metal apply plate support ring.
osirus5164
osirus5164
Top notch information, as always. Transparts is sending me the proper replacement and I think part of my goof was incorrect snap ring, though I'm gonna want to swap out some parts of the stack. Should I swap steels first or clutches? Does placement matter as far as toward the top or bottom?
Man, I could spend forever picking your brain and still learn something new. This build is my first and it's going to be fairly stock ish. I'm building a solid foundation and next will be the unit out of my son's 00 z/28 which we are going to experiment with more mods. It really is fun learning how all of it works, even if there is so much packed in haha. Anyways, thanks for your support!
mountie
When Art Carr rebuilt my 700R4, it was basically a stock build, but they installed a more stronger / race-style parts for strength and durability, with their hand-built converter. ( Plus, they knew how to beef up the valve body ( IMPORTANT)
When I sold my '88 GMC to a collector in Germany, the transmission had about 300,000 miles on the tranny, and that was 6 years ago. He says the transmission is still perfect. ( I had 392,000 on the truck when I sold it to him)
Tracyrsnbaum
