Cleaning up other people’s mess is the worst. It’s very possible that they had an amp for the speakers and just took it out. One thing you could look for is to see how many sets of RCA wires were ran to the aftermarket amp area. If just one set, then I would think they probably only had a bass amp. But if two sets of rcas or more than they definitely had an amp for the speakers, and when they took it out, you lost all audio to the speakers.I bought this truck with lots of problems that I'm working through one at a time. The deck was in it but I never heard it make sound. The PO made a mess of some things. There are wires for an aftermarket sub amp, but I still suspect you might be right. I thought about ordering a new interface harness with instructions and just redoing it cleanly, but they're kind of expensive. I need to do some diagnosis to make sure that'll even work.
Could that plug have anything to do with Onstar?
I'm in Dallas, have a Tech II clone, and no idea how to use it... I anticipate getting help with it in the coming weeks, but if you find yourself in my neighborhood, I am willing to share.Ah. Good advice. I think I will go that route. It’s definitely a Bose system but I think the amp may not be hooked up. The door panel I’ve taken off so far had an original speaker in it in good condition. So far, the messes the po made are mostly a bunch of pretty well run relay wires for lights and amp and stuff, but I haven’t seen any harness hacks. Some things are just left unplugged for no reason that I can tell, like the power mirror on the drivers side. I just plugged it in and it works. I would have no problem just running a factory Bose deck with some kind of Bluetooth input. I had one in an 06 table that I built on here years ago and it sounded good enough for me. I’ll check the junkyard or get a buddy to grab me one while he’s there. I’ll update when I get it fixed.
