07 yukon denali fuel pump control module
Warriorpluto
Can i use an used fuel pump control module from other years? Also i checked for a new module on ebay but they only cover 2008+. I know that 2007 has a different fuel setup than the 2008+
j91z28d1
I thought before 08 they didn't have a fuel modual. Just a simple old school fuel pump and regulator. if you check your under hood fuse box. see if t has a fuel pump relay in the spot called for. if you have relay, you don't have a module. if it's empty you have a module and life gets more difficult
Yeah I don’t see a fuel pump drive module for the 2007, only the 2008 and up according to Rock Auto. Also note that if you do have one, a replacement will need to be programmed with a bi-directional scan tool like a Tech2.
W
Warriorpluto
Is this the fuel pump module or something else?
j91z28d1
if you have the active system like air bags and or z55 shocks, that should be the module for that back under the spare tire
W
Warriorpluto
Oh ok this must be whats there then. Thanks alot. I also wasnt aware 2007 didnt have a fuel pump control module
donjetman
Midnigh_D_Tahoe
