2015 tahoe ppv, auto headlamps not working
Nvs07
Hello, not sure if there is a thread about this already but i was unable to find anything, i have a 2015 tahoe ppv, and the autolamp feature is not working, i have looked at the menus available in the car but no luck, does anyone know how to turn this feature on? Also does anyone know if theres a GM program similar to forescan to configure this tahoe? Thanks in advance
Tonyv__
Bucks county PA
It’s very possible your daylight sensor on the dash has been bypassed. They install a resistor in line so the car thinks it’s always sunny.
I did this on my van and learned it from someone who outfits ppv’s. (So they said)
N
Nvs07
Were you able to see the resistor by removing the sensor? Or was it buried behind the dash? Thanks for your comment i will try this tomorrow
Tonyv__
Bucks county PA
Really depends how it was installed if anything.. The sensor is on its own circuit that runs back to the BCM I think. So you could splice the wire anywhere along the way that’s easily accessible.
I spliced mine directly into the sensor. So the internals of the sensor are destroyed.
N
Nvs07
Thank you so much for the info
trashauler
