Power Steering Pump - '08 Tahoe
EddieC
I thought I had a leaky high pressure line but looking closer now I see that the ps pump is leaking a little in the area of the shaft right above where the hose is getting wet.
Question is are any aftermarket pumps an acceptable replacement? I see many names on RA.
I saw a video that seems to point to needing a tool set to remove and replace the pulley. The cost of that might make having the mechanic tackle it as he is probably tooled up but I am open to opinions.
Charlie207
LFOD, New Hampshire
EddieC
EddieC
You can rent the tool from AutoZone or whoever, and get your full deposit back after. This is what you want: https://www.autozone.com/test-scan-...r/p/oemtools-pulley-puller-installer/2075_0_0
It is easy to remove the pulley with the tool. I'll see if I can the instructional video on YouTube that made the most sense.
This is the pump I purchased from RockAuto: https://www.rockauto.com/en/moreinfo.php?pk=12747973&cc=3305735&pt=7380
This video; short & to the point:
Thanks.
I wondered about Edelmann seeing several different things that show.
Has it held up ok?
Charlie207
LFOD, New Hampshire
Charlie207
LFOD, New Hampshire
What brand of hoses did you use?
Edelmann Elite 80617E Power Steering Pressure Hose, and Edelmann 80618 Power Steering Return Hose.
I didn't replace the other hose, from the cooler to the low pressure side, because it was still in perfect condition. The other hoses were leaking/seeping where the hardlines were crimped to the rubber.
Finelfish
