Have lots of questions if you would be willing to answer.
Trying to get an understanding of the engine failures that occur after 7500 miles.
If you would be willing to answer the following questions it would be helpdful.
1. What City/State do you live in? Need this info to understand the climate conditions.
2. Is remote start used often to warm up the engine in the Winter/colder temps?
3. What fuel is typically used, Regular or Premium?
4. Is the vehicle typically used for trips shorter than 30 minutes on a regular basis?
5. Is the Auto Stop/Start typically turned off or currently bypassed?
6. Is the transmission typically run in L9 or is there a DFM bypass installed?
7. Is the vehicle used for towing and/or hauling heavy loads often? If towing, weight?
8. If towing or hauling, are elevation changes greater than 100 Feet or steep grades used?
9. What oil weight are you using? 0W20 or something different?
10. How often is the oil changed? Typical mileage? Per the OLM?
11. Does the engine consume oil? If so, how much between oil changes?
12. Has the low oil light come on often?
13. Are you the primary driver of the vehicle or your spouse?
If you do not want to post this info here, send me a Private Message, I will not share your details. Again, trying to get a profile for engine failures beyond 7500 miles to see if there are common factors. You are not the first and will not be the last failure in the mileage window from 12,000-45,000 miles which seems to be the window of failures beyond 7,500 miles.
