Escalade Mirror Upgrade Question
cmatt
Hi Dierk. I also build a harness that will add those circuits and enable the puddle lamps, turn signals and driver auto dim features. If you'd like to order, send me an email to [email protected]. Thanks.
JLNwebb0922
Thanks for your contributions! Today, I finally installed the brand new Escalade mirrors for my Tahoe (w/ driver seat memory). And I've noticed that all functions work except for the puddle lamps. For context, my stock factory mirrors had puddle lamps, and worked perfectly. Does you harness address the issue of only the puddle lamps not working?
K2 Kaiju
The Depths
Are you sure your new mirrors actually have puddle lamps? Some do not, but will fold, have blind spot, and turn signal....
JLNwebb0922
Update: I tried the puddle lights again tonight, and the lights are now working. I’m guessing the lights were just too dim to notice in daylight. But I swapped the standard puddle lights for the OEM Chevy bowtie LEDs. Pleased with the final product. Now debating integrating the cameras…
RST Dana
OH
If your existing mirrors had puddle lamps, the eskys should work if all your connections are solid AND your eskys have puddle lamps. I’ve seen a variety of options for the eskys. Some with/without puddle, blind spot or heat.
Vipverbob
Update: I tried the puddle lights again tonight, and the lights are now working. I’m guessing the lights were just too dim to notice in daylight. But I swapped the standard puddle lights for the OEM Chevy bowtie LEDs. Pleased with the final product. Now debating integrating the cameras…View attachment 407241
Do you have the part numbers for the mirrors you ordered? Thanks
Vipverbob
Thanks. I however had ordered a set of used ones on Tuesday before your post. Plus with the strike, I doubted I would get them. They are already installed and AWESOME!!!! 1000% better. Thanks though to document the number for future.
Loki223
Elk, WA
Does anyone have the part # for the bow tie puddle lights? that ones i'm finding on one site say they fit everything 2015+ and other with the same part claim only the newer stuff, knowing GM i'd wager they are the same throughout from 15+ but curious if anyone has the correct verified P/N for me to go off of
Nutro
I have a 2020 PPV Tahoe. I wonder if the Escalade features will work on it? I really just want the turn signals and puddle lights or turn signals and power fold.
tashaa95
