Rear dual brake hoses
skpyle
@donjetman, if I may ask, what tools did you use to crack the hardlines loose from the upper ends of the hoses? I have that new hose assembly for my 2013 Escalade. However, when I was laying on my back under it, I could not get my fat hands and any kind of flare wrenches up there to crack the hardlines loose.
I will gladly take any advice you have for doing this job.
Thanks!
Foggy
KS
There is the set called JOUNCE from GM . Then the aftermarket just shows
individual center lines... IDK what the diff is.
The indiv lines are diff lengths (longer) for the 9.5 rear end.
Super Moderator
Elev 5,280
Thanks!
You might want to tag @donjetman like this if you want to be sure he gets a notice that he's been mentioned...
donjetman
donjetman
Thanks!
Here's what I used:
My vehicle doesn't have any corrosion, that helps.
And I have a lift.
Move any/all evap lines out of the way.
Have the master cyl full and leave the cap on.
Leave the 2 L brackets attached to their mounting points until you have the 4 fittings broke free. Don't totally undo them (4) yet, just crack them (4) free to minimize fluid loss.
Work quickly so as to minimize brake fluid loss from the master cyl. When I started the job fluid was at the MAX line, and when I finished it was at the ADD line. This makes bleeding the brakes easy.
I removed the bottom 2 first, attached the new 2, set the other loose end up on top of the cross member to minimize fluid loss (gravity), while undoing the top 2 fittings.
Remvove the ole hose assembly and a connect the top 2 lines.
Reattach the new assembly L brackets.
Refill master cyl.
Gravity bleed brakes. I did all 4 calipers starting at the furthest from the master cyl.
If you let that master cyl run dry/get air in it :( you will need a tech2 type 2way scan tool to bleed the brakes. I don't own such a device.
skpyle
Excellent! Thank you very much for the advice.
I have a pressure bleeder and a Tech 2.
I don't have a lift. But I know someone who does...
Appreciate it!
Ja1034
