Glitter in 6.2L oil ... please help
rdezs
I recently did a test with the Valvoline on the neighbors 6.2, couple thousand miles before we did the AFM delete just to see how it did. It definitely cleans the internals, and it seemed to do it slow by dissolving. Didn't find any large pieces in the expected places, like in the oil pump relief valve. It was just simply clean. I'd be nervous using the standard engine flush that you run for 15 minutes. .. that stuff might send good size particles into the lifters.
rdezs
Here's what the lifters look like at just under 200,000 miles, with two oil changes with the Valvoline R&P.
Oil pressure relief valve from the OEM oil pump
And here is what your VLOM plate looks like underneath. Notice there's no o-rings on these later models, it's more like a molded gasket. Probably why GM says you need to replace it when you remove it. I can only surmise that the clean areas are areas the Valvoline was working where oil was spraying out, lowering his oil pressure. His o-ring was pretty much like yours also
Geotrash
Dave
Richmond, VA
That pan has evidence of several extended oil change intervals all along the sides. The pan in my 2012 was relatively clean with just a brownish staining at 120K, and no carbon buildup like that.
This is what a damaged cam lobe looks like. Note the deep scar along the edge. This was caused by a bad lifter tray that allowed the lifters to twist slightly:
Here's another lobe:
And here's one of the lifters:
thefrey
thefrey
I was only able to take pics and I couldn’t touch anything so I can’t get a super good feel for it. But this is what most of the lobes looked like. There are some surface scratches but I feel like for a cam with 200k on it that it looks decent
thefrey
thefrey
That’s some pretty nice testing you got there’s. It sounds like everyone swears by r&p lol. I’m not sure if my VLOM was replaced but it might be something I’ll consider in the future
Geotrash
Dave
Richmond, VA
Those look fine for 200K. Normal wear patterns on those two lobes at least.
thefrey
thefrey
That should bring your oil pressure up, eliminate the ticking sound. I'd run some Valvoline r&p through it... First batch I change after 500 miles. Second one maybe 2000 miles. And I'd probably keep changing it every 2000 until it stopped looking ugly when it drained. Then start changing every 4500 miles with a full synthetic
Well, I just did a road test and it seems like the new o-ring helped my cruising pressure by about 10psi so I’m around 30 cruising now. But my idle pressure really didn’t change much. My oil pressure seems to build quicker though. I wonder if my VLOM needs help
Upperorbital
