Bolt extractor head broke off - advice needed
alvocado
Cincinnati, OH
I'm having one of those days. I pulled my passenger exhaust manifold to address a leak due to a broken manifold bolt. As luck would have it, the bolt snapped below the head surface but was the forward most bolt with decent access. The oil dipstick tube is also rusted to the block but I can work around it to get a new gasket on assuming I get the bolt stud out.
I got a left handed drill bit on on the stud and drilled a solid, centered hole. The bit wasn't grabbing the bolt so I tried an extractor which bit immediately. I started turning the extractor with a wrench by hand and it was very tight. Then the extractor head snapped off in the bolt stud.
Now I have a chunk of extractor stuck in the bolt creating an uneven surface that's impossible to get a drill bit on it. I don't weld so tacking a bolt on unfortunately isn't an option.
Any ideas from those who've been down this road?
rdezs
The extractor is made from tool steel.... Forget about trying to drill it with any sense of accuracy. Accurately spot welding another bolt to the end of it is probably your only option. That will take one very steady hand, and someone with a lot of welding experience. (They'll pretty much be able to take a look at it and know exactly how many amps, etc)
How far ended the extractor go before it grabbed? If it grabbed it right away, I would first try a very small sharp pointed punch, and try to get it to turn and release.
rdezs
A quality tool shop will have a diamond bit for a die grinder, flat on the end. But even that will take some time, rotating clockwise.... And with the heat and vibration it might just rotate it enough to fall out. I have one I picked up for about $20 several years ago. Not sure what they run these days.
alvocado
alvocado
Cincinnati, OH
The extractor bit immediately and I didn’t get one full revolution before it snapped. It was very hard to rotate.
Using a punch is a great idea. I’ll try that and attempt to reverse it out.
alvocado
alvocado
Cincinnati, OH
No movement with a punch and the tool steel is so hard, it's tearing up the punch face. I'm concerned that the extractor bit may have started to bite the bolt sleeve lining which may have been why it was so hard to turn. If that's the case, I need to get the tip out cleanly from the broken bolt before taking another run at the bolt stud.
I think I'm looking at pulling the head to take to a shop where there's room to work it on a bench. Not what I was signing up for but that may be the most efficient route at this point.
GMT800 SUV/Trucks
Military
Make sure you chase all the other threaded holes in the head and clean gasket surface thoroughly. Get and install a Dorman exhaust clamp kit and use that and leave the broken piece in there. Or pull the head.
I looked and according to what I see, there is a Dorman clamp that works on left front or right rear but not on the right front.
alvocado
alvocado
Cincinnati, OH
I'm not familiar with the Dorman exhaust clamp kit and just looked it up. This could be a solution, permanent or until I have a reason to pull the head for lifters, etc. It's definitely worth a try. Thanks for the tip!
lordmorgul
