KEY FOB --- Won't Program
fishHoe
Palm Beach Gardens, FL
Have a new set of key fob's --- But feel I wasted money on new FOB's because the signal from the truck is not working? How do I reprogram if the truck is not locking and unlocking during programing of these new remotes?
Is there a way to trouble shoot?
01yukonslt
need more deebeeeez!
Spokane, WA
sometimes it takes longer than the directions say to unlock/lock try holding it for a little longer if its more than like 30-45 seconds then its probably a bad receiver in the truck.
F
fishHoe
any way to test the reciever? reset it ?
---------- Post added at 10:49 AM ---------- Previous post was at 10:43 AM ----------
what if I cannot get the door to lock and unlock? receiver shot???
F
fishHoe
new batteries and cannot get the truck to lock and unlock --- guess the receiver is shot --- how much is a new reciever? cannot stand being without a FOB!!
chauncey0337
MLT, WA
Also, make sure you have the correct fob for your vehicle- check that the GM/UTA # on the back of the fob is compatible with your truck. When I bought my new fob the seller told me to check the # on my old one. There are 2 different ones.
Alex33
I'm curious about this as well. I've tried multiple times to get replacement key fobs and they will never program. Every dealer and replacement specialist I worked with has said that there is a problem with the truck itself, not the fobs. I just assumed the receiver was part of the BCM or some other expensive part.
Cliffs: In for PN or pricing on new receiver.
ajaxnxs
Rockwall,TX
if these dont work and you can return try using www.keylessride.com They will use your vin # to get the right fobs and get you set up with programming too!
F
fishHoe
GOT it WORKING ---
Drove me crazy a couple weeks and then one day the program worked.... I was happy as can be when I slowed the process of cycling on, off and on off --- very slow and didn't rush the process and then the program worked!!! AHHH to have the POWER of the FOB back!!!!
Thanks for your help!!
Mrfirewolf1000
