2009 Tahoe Oil Leak
09tahoehybrid
Ohio
Hi All,
Its been a while since i've logged on to TYF, since I no longer drive the Tahoe Hybrid, but I've fallen into old habits and spent about 2 hours reading posts since logging on today! :)
My wife has been driving the Tahoe for the last six months.
Yesterday, I noticed this pretty big oil spot on the garage floor from the tahoe. Checked the dipstick, oil level is fine, no problems when driving and no DIC messages so far.
According to my wife it did leave a spot like this earlier this week at her work parking lot as well. Its definitely engine oil.
The oil & filter were changed about 3 weeks ago by the dealer, during a routine service appointment. (mobil 1 oil as always)
The truck has 45,000 miles, and doesn't really have any issues so far.
Do these 6.0L engines have oil leak issues?
I've scheduled an appointment with the dealer for this Thursday, and will monitor the oil level, adding more if need be.
Does anyone have experience with oil leaks with NNBS trucks?
Thanks guys
Here's the leak (pretty big leak?),
soulsea
Bar
This might be your problem right there ... I took my HyHoe once for a routine oil change at the dealership and it started leaking oil shortly thereafter. Turns out they didn't screw something in tight enough or something. Must be something with the early hybrids cause I had to go back twice to make sure it was screwed on tight. After that it never leaked again.
Hopefully it's something that simple.
09tahoehybrid
09tahoehybrid
Ohio
That is pretty big.
Have you looked up under the truck yet?
No, not yet. But good idea, i should.
Hi Serge. Yeah I thought about that, its so easy to change the oil on these trucks its sad if these guys can manage to screw it up.
Im thinking all that could be loose is either the filter or the drain plug.
soulsea
Bar
Yeah, these are the same geniuses who pulled the hybrid battery safety lever under the back seat to service the truck, didn't put it all the way back in, I hit a pothole, it popped out, and the truck shut down dead in front of Penn Station in the middle of NYC rush hour traffic. That was a fun day. :emotions34:
09tahoehybrid
09tahoehybrid
Ohio
Jeez I remember reading that...There was a window in the service waiting area so I saw the guys working on my car. Young guys, didn't look very experienced. was not impressed. to be fair though im not sure if it is their fault yet.
edgaranah1
Corona California
Damn if its a dealer screw up I would be pissed. Especially something as simple as an oil change. Have you looked under the truck at the oil filter too see if it shows any sign of leakage?
Sent from my iPhone 4g using Tapatalk
09tahoehybrid
09tahoehybrid
Ohio
Checked under the truck. There is some oil on the filter. Maybe they overtightened the drain plug and cracked something? I wont be able to make it to the dealer before Thursday unfortunately.
Im confused though....the oil was changed about 4 weeks ago, considering the puddles of oil have been pretty big its surprising the oil level is still in the normal range.
edgaranah1
Corona California
These trucks take 6 quarts of oil. I'm pretty sure you haven't wasted more than 1/4 of a quart with that pic you posted.
You probably just have a loose oil filter. Get down under and hand tighten it and see if that solves the issue. I wouldn't wait til thursday if I were you.
09tahoehybrid
09tahoehybrid
Ohio
Just checked under the truck, the filter is tight. But it might be cross-threaded or something. I cleaned the filter really well with a cloth, then ran the engine for about 10 min I'll check in a little while if oil is on the filter again. Weirdly the filter has a big letter "E" written with a white marker on the bottom of it by someone...not sure what thats supposed to mean.
KodiMoe
