RT rear blinker issue
sgtmac
This morning my RT side blinker started speed flashing, front works, no rear. I figure it's the bulbs, but they all look good, replaced anyway, still no dice. The socket looks kinda nasty, figure I can replace that circuit board? Anything else I could check?
Normal bulbs and and all other lights work.
If it is the just the CB, would an Autozone part work or is there a better route?
Thanks
S
sgtmac
just check for corrosion in the board, wires and grounds. any board should work.
Yep, that was the ticket. It's an Autozone board, and it works but the fit isn't great. I will have to find a better board, but I am up and running for now.
Thanks
jdpber
GOLD MEMBER
The America
I'm telling you make sure the blinker fluid is topped off and your good to go
S
sgtmac
G2G, got the high speed synthetic Amsoil blinker fluid, change at a less frequent interval and has a higher "blink" rate!
S
sgtmac
higher blink rate indicates the wrong fluid viscosity. you got the wrong ****.
Dammit, the guy behind the counter said it would give me 20HP, 30FTLb, 10MPG and I would look 40% sexier to only good looking women! WTF?!
terryseverson
