burning oil?
ebxgsxr
Baltimore, MD
just wondering if this is normal. when i 1st got the truck, i never noticed anything. there is no oil leaking onto my driveway and no white smoke coming from my exhaust. no visible signs of leaking in the engine bay.
but i noticed after 2 long trips (one to NJ & the other to NC) the check oil level light came on and i had to add about a quart of oil each time.
i don't think this is normal, but sometimes you never know. thanks for any info that can be shared.
godoy
utah
What kind of oil you use
What years your truck
Sent from jumanji!!
doylee4693
Tahoe User
New York
The pcv valve you have I believe has a spring in it which sometimes breaks and causes the oil use.Upgrade to a fixed orrifice pcv valve and see if it helps.I paid 7 dollers on ebay for mine.
E
ebxgsxr
Baltimore, MD
How many miles are you going before having to add a quart?
not totally sure. i haven't kept a track of the mileage. at first i just thought it was a one time thing. drove to Jersey city & on the way back i noticed the light when i stopped at a rest stop. added a quart & then it was out. i don't really drive the truck too much around town. next trip was a round trip to myrtle beach & back to baltimore. then a week later i had to take a trip to Selma, NC & back. my wife drove it yesterday & noticed the light was on.
so all i can say for sure is about 2,150 miles & i had to add a quart.
i'll have to look into that. i hope that would be it.
---------- Post added at 10:20 PM ---------- Previous post was at 10:17 PM ----------
you have a part number? nothing came up when i searched fixed orifice pcv on ebay.
DeepSeaFish
Holly Springs, NC
Usually if the check oil level light comes on, you've got a lot more than a quart missing. The oil pressure switch on the oil pan is located near the bottom of the pan. Sounds like a PCV valve going bad or your engine is using oil internally. How far between oil changes and are you using 'conventional oil' ? With that kind of milage, change every 3k with conventional or every 5 with synthetic blend or full syn. Are you the original owner?
Kman
Southern California
For the record I'm running 0W-40 Mobil1 and burn a quart every 2,100 miles. M1 is known to get consumed in GM motors. I'm going to switch to Rotella T6 at my next oil change and see if that helps.
dublo765
