What size engine could I fit in 02 z71 tahoe?
BigPhil
I'm thinking about swapping and putting a 504 in, do you think it would fit? If not what would be the biggest size I could fit?
livingez_123
Sandy, OR
It really depends on how much work you want to do, why stop at a 502 and go right to a 572. if you have the money and skills you can have whatever you want.
Gzes
the drifting 2dr
Wichita tx
Yup why not get a Ferrari engine? If u got loot to spend then get that
Z-56 Hoe
What do I do????
Houston
I've seen the 8.1L done. Low end beast but that's it low end he gets like 7MPG too
M Hankel
Vancouver, WA
A 504? What is that? BBC? Unless you like headaches it would be far easier to get a stroked LS engine that way you can keep your existing, motor mounts, fuel management, exhaust, intake system etc... As for stroked LS engines, the sky is the limit if your budget allows it, but a standard 408 is fairly affordable. The price goes up with cubic inches and cylinder head choices, 416, 427, 434, 454, etc...
What are you looking to do with it? For the price of swapping a large ci engine you could turbo your existing 5.3 or 6.0 and it would run circles around most n/a engines bbc or otherwise.
Mike
Hollys Denali 805
