Autoride bypass
fiatdale
fiatdale
Houstons Best
Houston
Cutting it off isnt a huge deal, just leave enough on the harness to solder back on if need be. Youll get a better connection with the resistors if you cut and splice than just sticking the wire in the connector. Not to mention a lot more weatherproof which is important on that part of the vehicle.
jplong
Cincinnati
Understood. But I'm talking about fabbing up the resistor to so that the orignal plug snaps onto it. Keeping people from splicing, cutting, soldiering, etc.
604Escalade
Will these resistors get rid of the message due to the air compressor being shot?
livingez_123
Sandy, OR
I found that when I pulled the RTD fuse and changed my shocks, my steering feel has changed. slow speed around the parking lot is ok but at speed it is real light with no road feel at all. maybe the resistors and putting the RTD fuse back in might help with the speed sensitive steering. any thoughts?
RoRo
TX
So you aren't running resistors and have the fuse pulled currently?
01Konvict
Boats n Hoes
Raleigh/SML
Does anybody know if these 25 watt 3.9 Ohm resistors will work to remove the ride height sensors?
BKraft
