newbie78
My drivers side interior door handle broke lose from the linkage now i gotta fix that tomorrow:poop::poop: I had that door panel off this past summer to replace the outside door handle now i gotta take it off again!
BirchyBoy
I hopefully resolved the last of my oil leaks by removing the fill neck. It was a real ***** to remove, too.
MACJR90
haven't done it yet but gonna install my fog lights on my tahoe limited once the fed ex guy shows up
Gzes
the drifting 2dr
Wichita tx
Been haulin junk. My interior panel close is busted so gotta close by rolling window down a bit
rmodel65
fired it up after getting the quick disconnect fixed finally
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Put off doing my rear brakes, hydroboost conversion, and brake bleeds-cleanout again because I did not feel up to it. Will try again next weekend.
rmodel65
replaced a heater hose and found out the alternator has a loose terminal in the rear of it causing it to not charge properly. gotta put it and see if its something i can fix or if its something that needs to be replaced
SavageWarrior13
