No rear heat???
chevync
North Carolina
28f this morning so I fired up the hoe let her warm up, front heat works great, I went to turn on the rear heat, all I got was blowing cold air, any idea whats up?
chevync
chevync
North Carolina
Jesus, add antifreeze! lol I am losing antifreeze from somewhere, the motor only has 1500 miles on it, I thought my low coolant sensor was bad, it never overheated, I added a gallon of antifreeze and it's still a little low. I checked all fluids and nothing it leaking.
JesusArTorres
Tulsa, OK
That fixed the rear heat? I recently filled the coolant.
DansOtter
North Carolina
I haven't fixed it yet... still researching the crap out of it. I'm still a little vague on the part number to order. My part number is: 21997590. However it looks like I might be able to replace it with AC Delco prt # 15-73506. Here it is on Amazon:
http://www.amazon.com/ACDelco-15-73...automotive&vehicleId=2&vehicleType=automotive
According to Amazon, it fits an '05 Tahoe (which is what I have btw). $59 bucks is hard to beat, and their return policy is pretty good. I'll probably give it a whirl. I'll let you know if it works.
Dan
GMT800 SUV/Trucks
Military
You guys that were low on coolant, did you pressure test the system and look for leak. If system is full then can be the actuator but I have heard of taking them apart and cleaning and then working again.
Alphamods
