17 Yukon Denali
- Joined
- Jul 27, 2021
- Posts
- 78
- Reaction score
- 83
Ok. So driving to Fl. All seems to be running wells. I can see a noticeable improvement in MPG. Averaging between 21-23 chilling at 75 mph. Stop at the Buc-Wes in St. Augustine, as I approach the light at the top to make the right I feel a a vibration. Almost misfire like. As I get to the light to turn towards the station the vibration gets worse to the point that my stomach sank. However when I step on the gas everything is fine. While at the station, if I fled it a little higher the vibration stopped. So I decided to get gassed up grab some grub and continue. Made it to Boca around 2:00am. After unloading I disconnected the battery and grounded the terminals to each other and went to bed. Funny thing is, when I picked it up after the fix, the “Service Trailer Brake” light kept dinging about every 30 seconds and lighting up the idiot center. After driving it for a while it went away so I’m operating under assumption that the battery was drained. Which would strangely suggest to me that they didn’t disconnect the battery when they rebuilt the top end.
So I am hoping that this rumble/stumble was a result of something needing to be reset to relearn its new improved parameters. Meanwhile, I ordered a tuner from Black Bear and a catch can. I figured since it’s rebuilt I’m going to work with what I can to prevent any issues all while beginning to put collect up parts to put together a NON AFM setup.
Hope for the best but plan for the worst!!
