j91z28d1
After i ventilated the hood on thecopcar the incoming air temperature dropped pretty dramatically.
interesting..
I wonder if it's because you gave the air behind the fender somewhere to exit or if you just lowered the aover all under hood Temps. both are probably a good thing.
hmm
I knew a guy years ago that had a Lingenfelter 383 in a firebird, back when that was a big deal. those cars pulled air from the inner fender too, where the camaors went over the radiator to filters behind the fog lights. he never could good the times he expected from it, working with their tech on the phone they found him a local body shop that installed a NCAC air vent right in the fender where the filter was. we all thought it just looked cool, but I seem to remember he was very happy it ran what he expected.
Charlie207
LFOD, New Hampshire
it does, I thought it was a bit weird, something to do with how air flows around thru the fender? they are angled up, like air would flow down into the fender well. it's pretty sealed up really, besides what comes in around the headlight, I didn't see a real air pathway to the box they made behind the air box.
I believe it's a high-pressure/low-pressure thing.
Or, drainage.
Runfor5
Northern VA
I'll post some pics later, perhaps a standalone write-up since I did a combo of YouTube video suggestions out there, but undertook one of the larger projects I've done (def on this truck) over the weekend... complete cooling system revamp and while I had all the clearance from the radiator out, did the oil cooler lines. What a PITA those are!
I went into this job all worried about the 2 "T"-fitting connectors at the firewall and those came off within 3min haha. With the radiator out, I was able to sit up in between the radiator core support and engine (if you can picture that), which helped to guide the lines out the back with a combination of fancy maneuvering and neck pain.
Install of the new lines was easier than removal of the old ones! Crazy but I'll take it. Oil filter had to come off + front driveshaft disconnected at the front diff + front cross member removed (painted while it was off) + and then loosened all 4 mounting nuts/bolts for the front diff to drop it idk 4" or so.
I did not unplug the knock sensor (couldn't comfortably reach it) and I did not touch the motor mount nor fender well liner.
Also thanks again to @Geotrash for the aluminum Denso radiator suggestion! Install went without a hitch.
St. Louis
Cutting old lines in multiple places makes removal much easier and quicker, unless you plan on saving them for some reason
Geotrash
Dave
Richmond, VA
I'm glad it went well for you! This weekend was my first real test of that radiator over a long haul (7.5 hour) tow through the mountains in 93ºF ambient temps. It did great! Very happy with the results.
Unfortunately, the rear suspension compressor took a dump on the drive home today, so I have a replacement on the way. It's a quick job.
RooTBeeRthe1st
I’ve not seen the vararam intake :shrug:
The volant and this Corsa may very well be at the least very similar if not the same. I know the price is super similar. I jumped on this one because I got it at a $50 discount. I ran a Corsa intake on my ‘17, too, and liked it so knew I’d get one for my ‘09 once I had enough pennies collected. It’s a nice quality unit for sure :waytogo:
Only downside is the instructions suck pretty good but other than that I’d recommend
Did you tune it, or was your maf happy in the larger tube?
RooTBeeRthe1st
I still need to figure out which louvers I want on mine and get them and do that...
Temps are already ridiculous.
And just recently, my underhood blanket fell apart so I ripped it out.
Dremar79
