SABreivogel
- Joined
- Jul 11, 2024
- Posts
- 2
- Reaction score
- 0
Hello,
So my wife and I bought our 2007 Chevy Tahoe a couple months back and love it so far. It has been a great vehicle for our family. We drove the vehicle for around 4,000 miles before changing the oil as the previous owner stated that he just changed it. I put Mobil 1 High Mileage Full Synthetic 5W-30 and a Mobil 1 filter when I changed the oil. I have since had another oil change on it after 5,000 miles and like to keep up with the changes like this in all my vehicles. Well, it has a ticking noise that I presume is a lifter at idle. It will only tick after driving it and then sitting at idle for around 3-5 minutes. No ticking at cold start and sitting for a bit after the cold start. Only ticking after taking it for a drive then stopping. My oil pressure gauge sits around 20-25psi at idle and 38-40psi when driving. When it develops the tick, I can increase the RPMs and the tick goes away. So I can only assume that the lifter is not getting enough oil at idle. I discovered maybe too late about the AFM systems in these motors and the issues that they can have. The previous owner did install a Range AFM disabler but unsure as to when he actually put it on the truck. I also really never owned a vehicle where the oil pressure does not constantly stays at 40psi even at idle (This is my first GM vehicle.) Is this normal findings for oil pressure readings? So my thought process now is maybe the oil pump needs replacement or maybe a different kind of oil and filter? I also read about the O-ring on the oil pickup tube needing replacement as well. The oil is topped off and not low when this happens as well. All thoughts and fixes are appreciated as I feel that I made a mistake on this vehicle now.
The vehicle:
2007 Chevrolet Tahoe LTZ 2WD
172,000 miles
The vehicle:
172,000 miles
