5.3 engine tick ONLY in Drive/Reverse
Bama704
Bama704
Charlotte, NC
Thanks for all the helpful replies, I will start looking at the starter first, then go from there if that's not the fix.
I thought this was the 07-14 Tahoe section, with a 2013 Tahoe wouldn't it fit right in? Where should I have put it?
Fless
Super Moderator
Elev 5,280
You're in the right section for your 2013, but your signature can be misleading. If the 2013 is in your fleet, consider adding it to your signature. Or if you've upgraded to the later model, edit your sig.
dangerman4203
