Partial List of Front Torsion Bars
Marky Dissod
Here is part of a torsion bar chart batboy found Dec 2017.
Added to the list from this post
15048307-LH (6XK) (Max torque 4553)
15048308-RH (7XK) (Max torque 4553)
15048309-LH (6XL) (Max torque 4626)
15048310-RH (7XL) (Max torque 4626)
15712407-LH (6WX) (Max torque 4863)
15712408-RH (7WX) (Max torque 4863)
Question 1: what's with the ratings gap here?
15048311-LH (6XM) (Max torque 5638)
15048312-RH (7XM) (Max torque 5638)
15712407 - LH (6WX) (Max torque 5826)
15712408 - RH (7WX) (Max torque 5826)
15528955 - LH (6GF) (Max torque 5826)
15528956 - RH (7GF) (Max torque 5826)
15058267-LH (6YH) (Max torque 5913)
15058268-RH (7YH) (Max torque 5913)
15712409-LH (6WY) (Max torque 5913)
15712410-RH (7WY) (Max torque 5913)
15528957-LH (6GG) (Max torque 6709)
15528958-RH (7GG) (Max torque 6709)
15528959-LH (6GH) (Max torque 7161)
15528960-RH (7GH) (Max torque 7161)
15712411-LH (6WZ) (Max torque 7267)
15712412-RH (7WZ) (Max torque 7267)
15528963 - LH (6GK) (Max torque 8615)
15528964 - RH (7GK) (Max torque 8615)
15528965 - LH (6GL) (Max torque 8782)
15528966 - RH (7GL) (Max torque 8782)
15732338 - LH (6XG) (Max torque 9054)
15732339 - RH (7XG) (Max torque 9054)
Question 2: If anyone notices that they have one of the pairs listed above,
Please sound off with which pair your vehicle wears, and your year/make/model vehicle?
Question 3: If anyone has more to add to this list, PLEASE DO!
Thanks.
Alex_M
Pulled a set out of a 99-02 Z71 Silverado once - don't recall the number or exactly which year, may still have them. They were the same number and not marked differently for LH and RH.
M
Marky Dissod
1st guess'd be, torsion bars from any light duty GMT800, should be functionally compatible /
/ functionally interchangeable with any other 1500 GMT800.
But I've been wrong before.
So I think I'm asking:
are Tahoes, 'burbans, Yukons L & XL, Escalades & ESVs, and Silverados & Sierras
capable of using any of the part numbers above ?
Pulled a set out of a 99-02 Z71 Silverado once.
Don't recall the number or exactly which year, may still have them.
If you can glean any more info it'd be helpful, thanks.
M
Marky Dissod
GMT400 (1988 through 2000)
GMT800 (1999 through 2007)
GMT900 (2007 through 2014)
GMT K2 (2014 through 2020)
GMT T1 (2019 through ... )
War_Pig
North Alabama.
I found it on my glovebox sticker.
These are apparently no longer made and I need new ones. Go figure.
(edit)
These are a tad pricey but would fit the bill it seems. Anyone used these as replacements? The site doesn't seem to list them as a matched pair. All the chassis codes are different between left and right sides that are listed.
M
Marky Dissod
(edit)
Your Tahoe SSV (SEO 5W4?) uses 6WX & 7WX front torsion bars?
M
Marky Dissod
@War_Pig,
does your Tahoe use 6WX & 7WX front torsion bars?
Anyone else with a Tahoe PPV or SSV that used
_XM, _WX, _GF, or _YH front torsion bars?
M
Marky Dissod
Hopefully someone finds this useful ...
M
Marky Dissod
Partial update of partial list of torsion bars:
15058265-LH (6YF) (Max torque 4863)
15058266-RH (7YF) (Max torque 4863)
Not rhetorical - anyone have an answer?
15072933-LH (6YK) (Max torque 7267)
15072934-RH (7YK) (Max torque 7267)
If anyone has anything to add to this list, PLEASE DO.
BrancoRST
