02 Sensor Issues - MAF, Sensors, What else?
TheEnder53
Hello all.
I’ve had some confusing issues with my Tahoe since I bought it stemming from the 02 sensors.
Originally, when it was colder out, I would get a repeated P0157 only if i beat on it. Had to be at or near wide open throttle for it to set. I was able to get it smogged here in California.
Now, it sets all the time, even when i’m not beating on it. It takes a few miles, but it will always set.
Today, after coming to a stop, i realized it had literally no power at all and would rev all the way up to 3-4K with light throttle and then shift very fast (like it had a shift kit) and struggled to hit 55 on flat land. Checked codes, had a code set for P0131.
Cleared it, hasn’t come back since. P0157 is there still however. The B2S2 02 Sensor is new (replaced in March) from Autozone and reads 0V at all times according to my scanner.
Unrelated, or possibly related, today was a very hot day. Around 115°F here where I live. Stopped in traffic because of an accident with my phone hooked up to it the engine was hovering around 225-228°F, which in my mind is overheating. It cooled down if I put it in neutral and revved it to around 1500 RPM. A/C was also blowing maybe 10° colder at best. Sounded like a jet engine once traffic cleared though and it returned to normal temps.
Reading around i’ve heard a few people say it could be maf, or something else. Where do I start?
Multnomah Falls
To me, with both codes, sounds like you have a clogged catalytic converter and an emission problem causing it. Before we get deeper, can you share the year and engine size of what you are driving? Mileage? Is it a secret? Not all GMT800 vehicles have exactly the same powertrains in them.
strutaeng
Dallas, Texas
...multiple issues going on. :-(
Low voltage means lean, right? That may be your issue, it's running lean. Somehow not throwing a lean code like P0171/0174?
Overheating? Not sure, that needs it's own diagnosis by itself. Clogged catalytic converters is very possible. Running a vehicle with misfire for extended amount of time can damage the cats. Did that ever happen to you? Or give us the background on the truck. Are you the original owner, only driven to Church on Sundays? You just bought the truck and are racer car driver on training wheels? We have no idea?
Revving and not going anywhere? Transmission slipping? That needs diagnosis by itself too.
This can get expensive by the DIY throwing parts at it. Probably best to find a local trustworthy mechanic or shop nearby.
TheEnder53
TheEnder53
Yes. 2001 Tahoe LS 5.3 4X4. Has just a hair under 250,000mi on the odometer.
TheEnder53
TheEnder53
No lean codes at all. Just the P0157 and now the P0131 that hasn’t come back yet.
It hasn’t misfired at all, and without the P0131 setting it drives just fine with no power loss at all. It’s only when that code specifically sets to where it loses all power. I don’t believe the transmission is slipping as it engages all gears without issue.
I’m the 3rd owner from what I can tell on the carfax. No clue how it was driven other than the fact that the engine (from looking at it through the oil filler with a camera) was very clean. I will attach a picture below. I drive pretty moderately. Apologies for not including more, just been a wild day.
2006Tahoe2WD
Silicon Valley
"Just the P0157". I Googled "P0157 Chevy" This is what comes back.
P0157 stands for “Oxygen Sensor Circuit Low Voltage (Bank 2, Sensor 2).” This code is triggered when the powertrain control module (PCM) detects a problem with the downstream oxygen sensor. A damaged oxygen sensor, exhaust leaks, and a lean running condition are possible reasons why this trouble code is set.
rockola1971
Indiana (formerly IL)
Its 115deg where OP is? He live in death valley? As soon as that 2001 Tahoe leaves the driveway every morning it is singing the "I think I can, I think can" melody. Good Gawd 115deg! You live in an oven along with your Tahoe bro!
P0131 B1S1 ---Upstream of Cat 02 This is one of the 02's that controls your fuel injection
P0157 B2S2 ---Downstream of cat 02 This is one the 02's that monitors your Cat for performance and that is all. Has nothing to do with control of your fuel injection. It is simply a emissions warning sensor.
You need live data during the poor running event to see what your fuel trims and o2's are saying is going on. But a quick in dirty is get underneath to verify all wiring from o2's are intact and not rubbed up against ground or melted up against something metal also verify wiring harness for ignition coils on that bank as well. Could have an injector on B1 hanging open randomly.
The PCM with its code is pointing you where to start looking by telling you the bank that is having problems. Wouldnt pay too much attention to the B2S2 right now UNLESS you take IR thermometer ($30 amazon, ebay, harbor freight) of the inlet and outlet of B2 Cat. If your Cat outlet is substantially lower in temp than the inlet then Cat is plugged up. While you are under there and engine running go ahead measure both Cats.
My man dont need no grill. He just slaps steaks on his porch concrete until done to likeness.
TheEnder53
TheEnder53
Apologies for not responding sooner. Been a bit rough here, that and the fact I got a new phone and didn’t know how to log in for a bit. lol.
I can confirm at least according to data PIDs it’s running lean. It’s adding around +25% fuel trims on long terms and short terms for both banks. Yet doesn’t have a code for running lean, but the P0157. It was also retarding to spark according to HP tuners due to spark knock.
It’s been a while, and it still hasn’t set a P0131 again. And yes, where i was was quite close to death valley, lol. It was hell in the heat wave we recently had here.
Only thing to note, i’m not sure if the fuel filter has EVER been replaced in this. Same with the regulator valve. Everything under the hood appears to be completely original. I’m debating switching to e-fans as the clutch just cannot cool it down in temps this high.
It also is now starting to have a hard time starting occasionally. It’ll crank for a few seconds, catch a little bit, then crank for a few seconds again, then finally fire up.
rockola1971
Id replace that fuel filter immediately. It could be your cause of fuel starvation. The hard starts could be your fuel filter or your fuel pump is getting ready to die. But being that you are in a oven, that could just be vapor lock. Fuel regulator is cheap and easy to replace, but i can be checked for a torn diaphragm.
Wbill99hoe
