06 Tahoe Z71, It begins
ZEUS1
ZEUS1
yes sorry i have been swamped recently, here we are right now, motor is in, i am working through the wiring, not rushing anything. Also I am currently waiting on some hoses, and other parts before i can completely button it up. With the heat settling in here over the next week or so progress may be a bit slow.
ZEUS1
ZEUS1
Quick update, have not moved much closer on the Tahoe over the last month, spent most it traveling for work. I did have to move another project into the shop for a bit, but i got that one done.
Had to spin the Tahoe around, and put a wheel seal in a 75 year old tractor.
89Suburban
Bull in the china shop
SE PA
View attachment 437079View attachment 437080
Got some pressure on the sucker! Great ingenuity! Did the flange make it with bending?
ZEUS1
ZEUS1
Alright, i am back at it.
Replace power steering hose, install Drivers manifold and plug wires
AC Comp installed, and belts routed.
Starter and drivers side Manifold going in hopefully tonight. Then i will be starting to reassemble the front end. I still have to get my injectors cleaned and flow tested, and the manifold will go on.
Getting closer I can see the light at end of the Tunnel.
