vathames1
- Joined
- Dec 5, 2015
- Posts
- 5
- Reaction score
- 4
Like many others on the forum, I conducted extensive research on replacement magneride struts for my 2020 Escalade ESV Premium. I landed on the new ARNOTT MR-4262, which was advertised as an active replacement for the long wheelbase models (ESV, XL, Suburban). This is a complete unit, including the electrical connector. These can be found on the ARNOTT website and purchased with ease from RockAuto.
Install was straightforward as any other GM (Silverado, Sierra, Escalade, Tahoe, Suburban) 4WD where you have to get the right angles going in and up and whatnot. These come with the normal clips on the shock mount bottom and new bolts. You will note the top nuts are smaller; however have enough diameter on the flats to be secure. Side by side, the two appear to be the exact same length from top of the strut to the c/l of the lower strut mount (about 18.5")
For perspective, I was running a one-inch front spacer with the factory shock. My ground to fender height in the front with the spacer was 36-5/8 on both sides. After installing the ARNOTT MR-4262 with the spacer, the height was just at 38". That evened it out with the rear, which I did not favor at this time. I removed the spacer and the new height all said and done is right at 37". Rides great and no codes!
