DaveO9
Got it to my local tuner today to make the axle ratio adjustment. He uses TunerCats and there ended up being 100+ parameters changed. I thought shift points were just based on RPM, but actually they're based on mph corresponding to throttle position, hence the need for many changes. It drove OK on the way to his place, but definitely better on the way home! Very glad to have my rig back after almost a month being down.
This was part three of my plan to convert my soccer-mom, grocery-getter Tahoe to a more tow-capable rig.
1. Converted single speed t-case to 2-speed.
2. Added heavy duty cooling, e.g. factory-style aux trans and engine oil coolers.
3. Converted 3.08 AR to 3.42, front and rear.
Essentially I think I've added RPOs NQH, K5L, and GU6. (Please chime in if there's anything more I need to do!) Why didn't I just look harder for one with those options?? Good question. This one came along when I was looking after my '09 was rolled. It's in great shape, had new tires, and the price was unbeatable: I paid $7500 for it when similar mileage and condition at a dealer would have been in the neighborhood of $12K.
Next on the list:
1. Full flush on the brake system. I did some today - replaced fluid in M/C and got the system bled enough to have a firm pedal, but my Holt power vacuum bleeder just doesn't seem to be able to pull fluid through the back brakes. It pulls great through the front though, so I at least flushed out the front of the system. I have to decide if I'm brave enough to try the bleeding procedure with the Tech 2.
2. Need to flush the P/S system, too.
3. Install a decent quality brake controller.
Next on the list:
