Installed resistors to get rid of Service Suspension message after removing Autoride.
mportkiller
I have read that thread previously, so yes I was able to use the search function. I still had questions about the resistor and if I needed to remove the compressor fuses too. What about ride height sensors? Anything need done with that? I have put the resistors on all 4 shocks and removed the fuses, but I still have the service suspension warning.
Sent from my SM-N920V using Tapatalk
Chris_from_cincy
I recently replaced all 4 of my autoride shocks with Bilstein 5100 shocks. To turn off the "Service Suspension" DIC message, I installed a resistor on each of the wires that used to connect to the Autoride shocks.
The resistors are: 3.9 Ohm 25 Watt 5% wire wound. I bought these on Amazon.
Here is where I prepped the resistors by soldering and heat shrinking some wire on to each side:View attachment 71443
Then I cut the connectors off each wire that used to connect to the Autoride shocks and connected one resistor in each of the 4 corners of the truck. I heat-shrunk all of the connections to protect against water etc.
An example of the front driver side:View attachment 71444
An example of the rear passenger side: View attachment 71445
Then I tucked them up into safe spots and zip-tied them to the frame.
This has successfully turned off the DIC message for me.
What GA wire did you use? is that .10GA?
klathan2015
San Jose, Ca
I have a 2013 Suburban 1500 4WD LTZ that had the Z55 suspension. I switched to Fox Shocks.
I used 4 - 50 watt 1ohm resistors on each corner; my Service Suspension light was still on. I used 4 - 25 watt 3.9ohm resistors. Service Suspension light came on.
Im not sure what to do next. I just thought I'd share my experience. No luck
str8wire
Do you like the Fox shock? and were you able to get the service light off? I have a 2008 Suburban 1500 LTZ and was thinking about your setup.
Thanks
klathan2015
San Jose, Ca
The fox shocks are awesome. The warning message on the dashboard still pops up. I've jus grown to see it as normal.
35inch tires
20inch wheels
4inch BDS lift Kit
