Best Motor Oil?
Pandabird
Finland
Here I was thinking oh hell yeah tell me what exact treat my 5.3 flexfuel will want to live a little longer.
Couple minutes in and I'm almost none the wiser. Fully synthetic seems to be the way to go?
Back to deciphering label code numbers I guess.
Currently looking at something called "comma syner-x 5W 30 Dexos1" that was recommended to me having never heard of the brand before. Another option would be "Castrol Edge FST-TI 0W-30 C3", well that brand I recognize at least. Anyways cold winters over here so I understand something that's best in Florida isn't what's best over here.
Edit; Having watched a bit further, I understand the difference now that it's a balance between performance, lubrication and longevity. Anti corrosion stuff wears off and burns causing clogs and whatnot, ph changes keep things more clean but corrode, lube tries to keep up, like some epic rock paper scissors game. Good watch really!
There will never be a cure all snake oil that will work everywhere in any situation, it all boils down to a lot of factors and the more sophisticated of a mix it'll underperform in areas it wasn't supposed to perform in. Big brands got it narrowed down, general brands keep it simple. There isn't a definite answer and the chemical composition is reliant on chemical compound quality which is always not the case. Got a bunch of old fancy tractor oil jugs with names and numbers I've never heard of, and google searches turn up diddly all, and the inherited 60's tractor seems to run fine on general purpose tractor oil for 4 years and still going. Is this the route I should take with my car as well? Probably not but perhaps some insight.
Question remains. prioritizing longevity, not going to run a lot. Yeah I just jumped into the rabbit hole didn't I.
j91z28d1
I have no idea what the best oil is but my take away from it all is just keep it changed and you'll be fine.
if yours tyring to go 15k miles between changes, run endurance racing or some crazy high hp where you need specific oil. if not you're probably fine just using whatever you grab in the weight your owners manual recommends for your climate.
blondie70
WalMart oil is unquestionably the finest for all applications. I use it so you know it's some super duper stuff. Don't sweat the fine print...use 10w-30 syn or natural dino...either one will work. Don't look back...you will be happy ...I garuntee !!!!
BacDoc
Vero Beach Florida
The oil geek guy definitely has the best data out there!
But as some have pointed out the frequency of oil changes is the most important factor when it comes to oil
teemassa8314
