viven44
Senior Member
Great to know. Thanks for the picture!shouldn't have to do all that, the tow button is integrated into the shifter arm and just snakes down under the column and then down to the bcm. if the wire is broke right at the shifter arm too short to repair then just get a new shifter arm. typically the wire breaks right wear it pivots from the shifter being moved up/down
just remove the plastic cover around the steering column and you have access to it right there.
