4wd Issues PLEASE HELP
CountryRoads
1995 Chevy Tahoe With Manual TC
Here's the issue:
We just got done replacing front differential with another one, everything works except 4HI. 4Lo is also slipping out .
I have an decently experienced mechanic helping me but he seems to be just as lost as I am on this matter! He thinks it could be the mechanism that connects the manual floor shifter to the transfer case isn't adjusted properly that's why 4lo is slipping
(sorry I can't remember exactly what that's called)
We had it completely up off of the ground, nothing except 2Hi worked before putting in the other Front Differential, Now 4HI isn't working. I have another Transfer Case, which he said seems to be functioning correctly. So if that's the issue, I'll try that.
The previous owner swapped engines in this Tahoe, so all the wiring on the engine was funky
Example: the fuel pump wasn't working due to a wire on the engine not being grounded. Could this be an issue with the Front Differential Or Transfer Case causing 4HI not to work? Sorry, I'm not that educated with these types of issues. I can repair if I know the issue.
We replaced the actuator in the front differential. There's seems to be what looks like a sensor also on the front differential. we didn't replace that, could that be an issue?
PLEASE HELP! We have 4 small kids , we live in a rural part of Iowa where they don't plow the road we live on! Which is a gravel road 6miles from the nearest plowed asphalt road. We were completely snowed in last yr and we're stuck for 2 weeks and DANG NEAR ran out of food/water. This year we're trying to be more prepared. Thank you ")
6 Miles from a plowed road? I would stay well stocked up or park closer to the road and buy a tractor, quad, snowmobile, sled etc for those times when access is limited.
no water well?
anyway, I'm sure you don't need a lecture on living off the beaten path a little
a mechanical 4wd is just that, what year did the replacement come out of?
pictures?
C
CountryRoads
no water well?
pictures?
We moved from city to a rural area and was not informed or aware that they don't plow the road we live on. The neighbor had to use their tractor to pull out all our vehicles and plow our drive way. We live on 3acreas so just the drive way is about 75yrds. I bought a plow for the Tahoe, a 4 wheeler and we're building a dogsled now (we have 4 Huskies) we are WAAAAAAAAY more prepared for this year's winter. But this isn't a forum for any of that, just need help figuring out this 4wd issue. The front differential is out of the exact same make and model. I'll post pics later this evening. Thank you
Don't know if this info may help, appears there may a vacuum actuator involved?
Eman85
This is a fully mechanical transfer case, nothing in there that "slips out".
It's all mechanical linkage, you can disconnect the linkage and move the lever by hand to select each position.
You said nothing worked except 2wd Hi to start with, all of that is controlled in the transfer case. Why did you change the front differential?
wjburken
Eastern Iowa
Welcome to the forum from a fellow Iowan. What part of Iowa do you hail from?
You’re getting some good advice here.
C
CountryRoads
We had the vehicle hoisted completely up off of the ground, Front wheels went doing anything but the front drive shaft was spinning. We took apart the front differential after we took it out and there were broken pieces inside and the grease on the inside looked like grey glitter paint. So it did need replaced. I'm just going off what my buddy is saying/doing. I've worked on cars my whole life, but mostly suspension and brakes, never anything like this, so I'm completely clueless. Thanks for your input, it all helps
blanchard7684
