2003 z71 tahoe
ncalvo
ncalvo
FL
My alternator was chirping - I assume bearings shot, and water pump was dripping tears. Replaced with alternator from napa.
Old waterpump was a cheap brand but lasted 5 yrs, the gaskets were caked on. Replaced with OEM pump + thermostat and fel pro gaskets this time around.
Everything is quiet and happy again up front
My dad and I are gonna go to a GM drive event next march I think it starts in TN... plannig to replace my oil pan gasket/pickup tube o-ring/oil and crank sensors and replace fuel pump and fuel lines before then
2591tdj
Miss
Wow! That’s a lot of replacement parts. Have you kept a tally on how much you’ve spent?
When replacing the headlights with LEDs did you consider also adding a headlight full light module so that all lights are on with the high beams? Amazon has them.
ncalvo
ncalvo
FL
A lot of replacement parts over the years for sure. I haven't kept track except for the big ticket items. I'd say over 14 years I have easily spent over 20k.
I actually recently saw that all lights on relay panel and will be picking one up soon.
ncalvo
ncalvo
FL
That’s the exact one I installed on my Tahoe. It works flawlessly.
Good to hear
Couple other things I am planning on doing replace my driver side mirror glass, the fluid must have leaked inside because it is tinted yellow.
Also going to try to fix the temp and compass digital display on my inside rear view mirror, from what I see it could just need some soldering on a couple connections inside it
2591tdj
Miss
Good to hear
Please post the source, cost and removal/replacement process for the mirror. I have the same issue with mine.
dacpdx
