Ok so i decided to play sick today from work and change that oil pump.
Started at 9AM and done by 1:45pm so not to bad and had a couple short coffee breaks.
Discovered someone had been working on it before. The crank pulley bolt was loose and not even finger tight.
Kinda makes sense. The PO told me new cam bearings had been installed a year ago but the oil pressure was still FKD and he did not have any receipts.
I figured yeah right, I don't believe that for a minute with the oil pressure it has and you don't install new cam bearings and still have bad oil pressure.
I'm buying it cheap believing it needs an engine and was 99% convinced after seeing the shiny stuff in the oil drain pan.
Taking it apart is easy.
1: I did not even loosen the oil pan to allow it to drop an inch.
2: Taking out the pickup tube bolt is not bad. Once loose you can turn it out with a screwdriver. Tedious for sure but it works. I used a strong magnet on the bottom of the pan to catch it in case i dropped it and i did but the magnet caught it and made it easily retrievable.
3: Take the oil pump apart and lightly pry on the pickup tube and the pump comes right off.
4: Coffee or Beer break, Your choice.
5: You will need to take the new oil pump apart to install it. Before you put it back on, be sure to clean the tube and install the green o ring. With a little wiggling and twisting, it will eventually slide into place.
6: The entire hard part of the job is getting the pickup tube bolt back in and here is how i did it.
I used a new bolt and cut about 16 tiny notches around the washer part of the bolt. I then put 1 wrap of bailing wire around to hold the bolt and allow me to feed it back into the hole. The notches allowed me to turn the bolt easy with a screwdriver. Once i had the bolt about halfway in i pulled off the bailing wire. Continued turning it with a screwdriver until i could get a box end wrench on it and tightened it down.
7: Reassembled the oil pump. Tightened it down making sure i could get a .001 feeler gauge around it.
Putting the cover back on and reassembling everything else should be self explanatory.
Forgot to mention i also found a bad o ring.
![20241108_112258.jpg 20241108_112258.jpg](https://www.tahoeyukonforum.com/data/attachments/436/436539-5ad8f61de4070db920f7800079c10821.jpg)
![20241108_111020.jpg 20241108_111020.jpg](https://www.tahoeyukonforum.com/data/attachments/436/436541-a8cfd6af5981f02e5c3a2ad16f218dcd.jpg)
