Simple question: What happens in your vehicle when you push the talk/mic button on your steering wheel?
djsassan
2023 Yukon XL Denali.
If you push the mic button, what happens in your vehicle? Do you get a response, or do you have to hold it down for 3 secs to get Google to answer?
Thanks
trckrhntr
Northern-Lower Michigan
When Scam-Star was still active, a quick push brought up voice command.
When the free trial was over it throws an error unless I hold it down, then Android Auto kicks in for use.
2023 Tahoe
WalleyeMikeIII
Sunny and Snowy Minnesota
There are 3 functions to that button, all described in the owners manual.
1) It will launch the infotainment google assistant with a press and release (assuming a connected phone is not ringing)
(2022 Yukon Onwers Manual, Pg 166 under "Infotainment Section")
2) It will answer a connected phone if ringing
3) Pressing and holding it for 3 seconds will launch a connected phone's voice assistant (Google Assistant when using a connected android phone and Siri when using a connected iPhone)
(2022 Yukon Owners Manual, Pg 168 under "Steering Wheel Controls")
D
djsassan
Thanks. Mine is not doing #1, only #2 and #3 since the latest firmware update. Curious is anyone else has this issue.
petethepug
Michael
SoCal
Just don’t push the do not push button.
Rtoutwest
