How wide of a wheel can I fit on my Yukon?
daulton-va
Im looking to run at least an 11 inch wide wheel on my Yukon with a 325/35/22. Is this possible? Was wondering if anyone else has run an 11 and if it pokes too much or if we have the inner wheel well clearance for it even.
Thanks in advanced
jgraves
Thanks for the info. I want to keep it like a street build in a way where it doesnt poke past the fender too much.
Although that does look really good, just not the style im going for this go around.
It's not my style either, but it demonstrates what is possible and his posts are very informative regarding wheel and tire fitment. They were a great resource and inspiration when planning my own non-OE tire fitment (315/70R17 on +18ET with fender liner pullback but no lift).
Jeff
D
daulton-va
Jeff
Do you have any photos of your setup? How wide of a wheel are you running?
jgraves
Here is my follow-up thread after running them for a winter. There are also a couple other photos of my truck posted on the forum if you search for my posts.
Jeff
Trey Hardy
Eastern North Carolina
What year body style do you have? I’ve got plenty of experience with 90-2013
When I got my 07 the first thing I did was throw some 20x12 on with 275 streets with no lift IMG_2147.jpegI was running 2” spacers all around that’s why there poking so much but without them they were just outside the fender well I cleared full lock with 275 streets on them
When I stepped up to 33/12.50s I had to run a 2-3” leveling kitIMG_4636.jpegafter the 20s I ran some 24x10 kmc slides on 33s and cleared no problem with the 3” lift and wheel spacers IMG_4797.jpegthis is all I ran while on the leveling kits I stepped up to a 8” lift with x14 wides after this which isn’t what your going for I’m assuming
Jeremy79
