Back after a hiatus: 2018 Denali Build Thread
WebCo
WebCo
Glastonbury, CT
Brought it home today! Absolutely loving it after the 150 mile ride home!
Question: the passenger side mirror signal is not working, but power adjust fold, and Blindspot all work. From what I could find on here it seems like the consensus is getting a new glass for it. Can’t seem to find an OEM part and I see a lot of people saying that aftermarket glass has a much dimmer signal than factory. For $80 on Amazon it might be worth a shot, but before I do, hopefully someone will chime in here with some advice. Thanks in advance
WebCo
WebCo
Glastonbury, CT
Wasn’t able to find any info on here for it, but I know the older trucks were direct swap and the connectors appear to be the same. Worst case, they all look like the same four wires so it should be an easy splice if not plug and play. Ordered this one today from a 2007 through 2009 Escalade that have the stitch on the front. Will post an update when it comes in and I try it out.
Installed one in my 03. Nice little upgrade.
RST Dana
OH
Before you cash out for a replacement glass, I’d check the voltage on the turn signal wire when it’s supposed to be flashing. It may not be the mirror glass
diverstan
