Rear coil spring choice
TexasPPV
Hi y’all
Looking at replacing my rear coil springs on my 2016 Tahoe.
It had the PPV suspension in it. I already replaced the front coilovers with 2 inch leval rough country.
Looking for a stock to 1 inch lift in the rear. Since the PPV is slightly lowered “stock” should raise it up a bit.
I am wondering which springs would be recommend? On GM parts there are about 30 options for different package and trim springs.
Thanks
Big Mama
Virginia
Welcome to the forum from Virginia. What you don’t want is springs that come with the Z55 rear auto leveling. They’re too soft. Did you look in the ppv section here? I’m sure some have done what you’ve looking to do.
emfadz
