2010 Escalade seat Heater module.
frank1
Hi All, The seat heater module on my 2010 Escalade is toast and needs replacing, one of the relays just buzzes. Do anyone know if the Ford truck module will work, the plugs/pins look identical.
a relay buzzing indicates a improper voltage or ground load, probably not the relay
as for the module, no idea proceed at your own risk......
petethepug
Michael
SoCal
Welcome from SoCal,
Lucky you, last year GM did True Chilled seats vs Recirc Air. I’d seen they did look very, very similar and at 1/2 the cost. Both made in Mexico.
Ford…
GM …
kmlink
